Ronnie Posted October 15, 2022 Share Posted October 15, 2022 I think you are making a mistake using a universal fit pump instead a spending a few more bucks and getting a pump made for a Reatta. I'll be surprised if it works. Good luck. Link to comment Share on other sites More sharing options...
Ronnie Posted October 15, 2022 Share Posted October 15, 2022 Carter lists it for a Reatta so you will probably be ok. 1 Link to comment Share on other sites More sharing options...
Padgett Posted October 15, 2022 Share Posted October 15, 2022 Is easy: in tank has a large connection on one end for the sock. Inline has small hose connections on both ends. 1 Link to comment Share on other sites More sharing options...
Padgett Posted October 15, 2022 Share Posted October 15, 2022 (edited) Looks like Delphi FE0039 is the kit and FE00115 is just the pump but sock end looks a little different. 039 has larger openings. Edited October 15, 2022 by Padgett 1 Link to comment Share on other sites More sharing options...
CarrieJT Posted October 25, 2022 Topic Author Share Posted October 25, 2022 On 10/15/2022 at 3:52 PM, Ronnie said: Be sure you use the short hose that should have came with your new pump (shown in my last photo. The rusty pulsator shown in your photo should be replaced with the hose. Get the hose clamps tight but don't cut the hose. Well rats. I didn't see this until now. I got it all back in there and left the rusty pulsator. It was clean inside.... So I left it... Got in, Turned the key. And POOF!! It cranked and ran as if it had never been left. HAPPY DAY! Thank you all for your guidance. Now, my next issue --ill start a new post after I review the articles 1 Link to comment Share on other sites More sharing options...
Ronnie Posted October 25, 2022 Share Posted October 25, 2022 Happy to hear it worked out well for you. Link to comment Share on other sites More sharing options...
Padgett Posted October 25, 2022 Share Posted October 25, 2022 And I ordered a FE0112 fuel pump. It has a higher flow rate than the FE0115 and I plan to use as a spare for both the Reatta and my 4.5 Allante. Link to comment Share on other sites More sharing options...
