2seater Posted June 13, 2022 Share Posted June 13, 2022 20 minutes ago, Cmanring82 said: Am I going to have to keep replacing the coil pack? when chasing a no start condition: replacing the coil pack and Ignition module below it should either be new parts or a used set from a running car. Both parts should be done together or you could have any combination of bad or damaged parts. Once it is operational, individual pieces can then be switched around to determine good from bad. The actual fuel pressure reading is important as mentioned previously, as well as the ability to hold that pressure for a reasonable period of time. 1 Link to comment Share on other sites More sharing options...
