Showing content with the highest reputation on 04/26/2023 in all areas
  1. Once again thanks to everyone for their help!!! This started with my finding a front brake 2000 Grand Am upgrade on line. I was unsuccessful with this. My opinion, for whatever it's worth, don't bother. Bleeding did not work at all. even though it seems to. I've changed everything back to OEM. Bled brakes exactly the same everything works. Would seem the problem is the bleeder valve position. OEM is positioned straight up, the Grand Am valve, points inward. perhaps an air pocket remains above it that will not bleed. Maybe a pressure bleeder will work, but my 200,000 mile go anywhere anytime driver, will be staying stock up front. P.S. The Park Ave 1998 rear upgrade works fine.
  2. Thanks Ronnie! Kevin [Kdirk] told me once that the dashes were the same, I was just concerned about what you had to do when you swapped in the '89 glove box.
  3. Jim Finn or Maark probably has a known good Delco. Think I paid $40 at a yard for a my last one complete with mounting plate.
