Bertimus Posted December 12, 2020 Share Posted December 12, 2020 (edited) So something is definitely draining my battery. I haven't had this car very long, but the gentleman who sold it to me told me that if the car sits for a while all the electronics drain the battery. But it'll sit for just one night and not start. I know this isn't the case for some lucky owners, but for those of you who have experience with this issue, what was the culprit for you? And I mean it's draining FAST. Any wisdom on this issue would be greatly appreciated ?? Edited December 12, 2020 by Bertimus Link to comment Share on other sites More sharing options...
rogold Posted December 12, 2020 Share Posted December 12, 2020 (edited) Could be a bad alternator. Or a interior light left on. Blower control module is common. Could be the alarm is activated but someone unplugged the horn. Bad Battery. Try this test Reatta Owners Journal then start pulling fuses until the drain disappears. Edited December 12, 2020 by rogold 2 1 Link to comment Share on other sites More sharing options...
Bertimus Posted December 13, 2020 Topic Author Share Posted December 13, 2020 UPDATE: So unexpected turn of events. The same day I noticed my battery draining, my radio antenna stopped retracting. I noticed that even after I turned the car off, the antenna motor would sound like it was still struggling. Went into the trunk and was able to get the antenna to manually retract, and then also disconnected the antenna motor. A few hours later the battery was still draining. For whatever reason I just decided to pull the fuse for the antenna. Since pulling the fuse, the car is starting much better and hasn't drained (although it's not starting as quickly as it does right after I jumpstart it). Just thought it was an interesting observation. Taking it get an overall inspection this week, will update on the situation. The electronics in this car are really something else Link to comment Share on other sites More sharing options...
Philbo Posted March 30, 2021 Share Posted March 30, 2021 On 12/13/2020 at 2:49 AM, Bertimus said: UPDATE: So unexpected turn of events. The same day I noticed my battery draining, my radio antenna stopped retracting. I noticed that even after I turned the car off, the antenna motor would sound like it was still struggling. Went into the trunk and was able to get the antenna to manually retract, and then also disconnected the antenna motor. A few hours later the battery was still draining. For whatever reason I just decided to pull the fuse for the antenna. Since pulling the fuse, the car is starting much better and hasn't drained (although it's not starting as quickly as it does right after I jumpstart it). Just thought it was an interesting observation. Taking it get an overall inspection this week, will update on the situation. The electronics in this car are really something else Hey did you ever get the antenna figured out? Mine literally just started doing the same thing ? Link to comment Share on other sites More sharing options...
Bertimus Posted March 31, 2021 Topic Author Share Posted March 31, 2021 On 3/29/2021 at 10:31 PM, Philbo said: Hey did you ever get the antenna figured out? Mine literally just started doing the same thing ? No I haven't, I just pulled the fuse on it for now so I don't have to listen to it struggle. it's pretty low on my priority list but I will give an update when I get around to it! It's a bummer ? Link to comment Share on other sites More sharing options...
Philbo Posted April 1, 2021 Share Posted April 1, 2021 19 hours ago, Bertimus said: No I haven't, I just pulled the fuse on it for now so I don't have to listen to it struggle. it's pretty low on my priority list but I will give an update when I get around to it! It's a bummer ? I did find parts geek sells replacements: https://www.partsgeek.com/catalog/1990/buick/reatta/fluids-fs-manuals-fs-misc/antenna.html 1 Link to comment Share on other sites More sharing options...
Bertimus Posted April 1, 2021 Topic Author Share Posted April 1, 2021 5 hours ago, Philbo said: I did find parts geek sells replacements: https://www.partsgeek.com/catalog/1990/buick/reatta/fluids-fs-manuals-fs-misc/antenna.html Awesome thank you for the link!! Link to comment Share on other sites More sharing options...
