Definite battery drainage on my 88
So something is definitely draining my battery. I haven't had this car very long, but the gentleman who sold it to me told me that if the car sits for a while all the electronics drain the battery. But it'll sit for just one night and not start. I know this isn't the case for some lucky owners, but for those of you who have experience with this issue, what was the culprit for you? And I mean it's draining FAST. Any wisdom on this issue would be greatly appreciated 🙏🏽
Edited by Bertimus
Link to post
Could be a bad alternator. Or a interior light left on. Blower control module is common. Could be the alarm is activated but someone unplugged the horn. Bad Battery.  Try this test Reatta Owners Journal then start pulling fuses until the drain disappears.
Edited by rogold
Link to post
UPDATE: So unexpected turn of events. The same day I noticed my battery draining, my radio antenna stopped retracting. I noticed that even after I turned the car off, the antenna motor would sound like it was still struggling. Went into the trunk and was able to get the antenna to manually retract, and then also disconnected the antenna motor. A few hours later the battery was still draining. For whatever reason I just decided to pull the fuse for the antenna. Since pulling the fuse, the car is starting much better and hasn't drained (although it's not starting as quickly as it does right after I jumpstart it). Just thought it was an interesting observation. Taking it get an overall inspection this week, will update on the situation. The electronics in this car are really something else
Link to post
  • 3 months later...
Philbo
Hey did you ever get the antenna figured out? Mine literally just started doing the same thing 😞
Link to post
Bertimus
No I haven't, I just pulled the fuse on it for now so I don't have to listen to it struggle. it's pretty low on my priority list but I will give an update when I get around to it! It's a bummer 😕
Link to post
Philbo
I did find parts geek sells replacements: https://www.partsgeek.com/catalog/1990/buick/reatta/fluids-fs-manuals-fs-misc/antenna.html
Link to post
