RI10121 Posted November 28, 2016 Share Posted November 28, 2016 Hello, Is there a paint product to touch up the alloy wheels and valve covers for the 3800 engine? If not, is there a color description for each? Thanks for reading, Henry 1988 Coupe, white, white trim, beechwood interior New member, Cranston, RI Link to comment Share on other sites More sharing options...
Ronnie Posted November 28, 2016 Share Posted November 28, 2016 Welcome to the forum Henry! There was a service bulletin on paint to use on the wheels. Here is a link to it. Aluminum Wheel Refinishing - Paint Colors I don't know about the color that was used on the valve covers. Link to comment Share on other sites More sharing options...
RI10121 Posted November 28, 2016 Topic Author Share Posted November 28, 2016 Thanks for this information. Henry Link to comment Share on other sites More sharing options...
Posti Posted November 28, 2016 Share Posted November 28, 2016 My 1989 Reatta has discolored wheels and caps, but no corrosion or scrapes. I was able to clean off one of the hub caps using brake cleaner and 0000 steel wool, and I think it will work for the wheels as well. The discoloration appears to be the clear coat rather than the metal, and the brake cleaner dissolves the clear without damaging the metal. I'll let you know how it works out. Link to comment Share on other sites More sharing options...
Ronnie Posted November 28, 2016 Share Posted November 28, 2016 My 1989 Reatta has discolored wheels and caps, but no corrosion or scrapes. I was able to clean off one of the hub caps using brake cleaner and 0000 steel wool, and I think it will work for the wheels as well. The discoloration appears to be the clear coat rather than the metal, and the brake cleaner dissolves the clear without damaging the metal. I'll let you know how it works out. That might work out really well. The aluminum wheels can be refinished but it is a lot of work. I refinished a set of Mustang wheels I use to have on my Reatta. It is documented here. Aluminum Wheel Refinishing Link to comment Share on other sites More sharing options...
Ronnie Posted November 28, 2016 Share Posted November 28, 2016 Thanks for this information. Henry Just as info: I think the only year that had painted wheels were the '91 models. Other years had aluminum clear coated wheels. Link to comment Share on other sites More sharing options...
RI10121 Posted November 29, 2016 Topic Author Share Posted November 29, 2016 My 1989 Reatta has discolored wheels and caps, but no corrosion or scrapes. I was able to clean off one of the hub caps using brake cleaner and 0000 steel wool, and I think it will work for the wheels as well. The discoloration appears to be the clear coat rather than the metal, and the brake cleaner dissolves the clear without damaging the metal. I'll let you know how it works out. Thank you for this suggestion. The wheels on my 1988 Reatta are in good condition. What I need is to touch up some small scratches and chips. I am looking at some automotive retailers and on line sites to purchase brush on paint. Best regards, Henry Link to comment Share on other sites More sharing options...
Posti Posted December 3, 2016 Share Posted December 3, 2016 Following up on cleaning the Reatta wheel caps, I got them all done tonight. I used brake cleaner, 0000 steel wool, some paper towels, NevR-Dull metal polish, and a clean rag towel. The caps on my car were very cloudy, due to the clear coat aging. I stripped off the clear coat with steel wool and brake cleaner, wiping the residue off with a paper towel. When I got all the clear coat off, I polished the metal with NevR-Dull and buffed it out with the old towel. As you can see in the photos, the difference is amazing, especially for less than 15 minutes a cap. I think the wheels will respond pretty much the same, as they have no visible damage. Link to comment Share on other sites More sharing options...
RI10121 Posted December 3, 2016 Topic Author Share Posted December 3, 2016 Your caps now look good. I used on the wheels and caps Mothers Mag Wheel Cleaner, (2 coats) applied with microfiber cloth. A few days later, applied two coats of Meguairs NXT liquid on microfiber cloth and buffed with Mothers Powerball. Wheels now look a lot better than before. Thanks for your suggestions. Henry Link to comment Share on other sites More sharing options...
Please sign in to comment
