Posti Posted November 25, 2016 Share Posted November 25, 2016 I am trying to replace the power antenna unit in my 88 Reatta and can't figure out how to get the coax lead connection in the trunk apart. Is there a trick? I don't want to damage it. I am referring to the metal tube connector between the antenna lead and the car's radio antenna lead. Thanks! Link to comment Share on other sites More sharing options...
Ronnie Posted November 25, 2016 Share Posted November 25, 2016 I replaced mine when Dave was here a couple of years ago. I don't remember anything but unplugging it. I could have took a couple of screws loose. Maybe Dave (DAVES89) will remember how to do it. Below are couple of photos of my old antenna that might help you. Link to comment Share on other sites More sharing options...
relospecialist Posted November 26, 2016 Share Posted November 26, 2016 I replaced mine a while back and remember the metal sheathing at the end of the cable was secured by flanges on two sides that simply need to be depressed. If it is hard to pull loose, expect it. You're working on a part 25 years old. If you are replacing the part then just cut the cable above the connection. This will give you more room to work on separating the plug. Link to comment Share on other sites More sharing options...
DAVES89 Posted November 26, 2016 Share Posted November 26, 2016 I can't remember exactly how it comes apart other then pulling it. If anyone else knows they can chime in. Link to comment Share on other sites More sharing options...
Posti Posted November 28, 2016 Topic Author Share Posted November 28, 2016 As it turned out, I was able to remove the lead at the antenna shaft - held on by two phillips screws. Swapped out antennas and it works great! Link to comment Share on other sites More sharing options...
Ronnie Posted November 28, 2016 Share Posted November 28, 2016 Great! Something else you can check off your list. :D Link to comment Share on other sites More sharing options...
