harry yarnell Posted November 6, 2017 Share Posted November 6, 2017 Um, how do you change the left front turn bulb? Link to comment Share on other sites More sharing options...
Ronnie Posted November 6, 2017 Share Posted November 6, 2017 Some people choose to change the bulb with the assembly in place: Front Parking Lamp Replacement I find it easier to remove the assembly to replace the lights: Parking Lamp Assembly Removal I replaced all the lights when I removed it the first time just to know they were all good. Link to comment Share on other sites More sharing options...
fordrodsteven Posted November 6, 2017 Share Posted November 6, 2017 X2 - I too pulled out the assembly and changed all the bulbs. Link to comment Share on other sites More sharing options...
Frogware Posted November 6, 2017 Share Posted November 6, 2017 Agreed! Plus you can clean out all the dirt that has accumulated in that area and around the wires. It also gives you a chance to inspect the wiring for cracks and to put more Tape/wire wrap around everything to protect it from moisture. Link to comment Share on other sites More sharing options...
Ronnie Posted November 8, 2017 Share Posted November 8, 2017 Harry, Which method did you use to change the bulb? Link to comment Share on other sites More sharing options...
harry yarnell Posted November 8, 2017 Topic Author Share Posted November 8, 2017 I'll get to it today. Probably removing the turn bulb only from underneath. I'm getting old and it's not easy getting up in that confined space. Link to comment Share on other sites More sharing options...
ski.dive Posted November 8, 2017 Share Posted November 8, 2017 I'll get to it today. Probably removing the turn bulb only from underneath. I'm getting old and it's not easy getting up in that confined space. Agree!! Just fix what broke......If it ain't broke=Don't fix it!!!! Link to comment Share on other sites More sharing options...
Ronnie Posted November 8, 2017 Share Posted November 8, 2017 I'll get to it today. Probably removing the turn bulb only from underneath. I'm getting old and it's not easy getting up in that confined space. I know what you mean. I'm getting there myself. Be sure you get a bulb that is the correct length. A bulb that is too long will damage the amber globe inside the housing. Good luck! Link to comment Share on other sites More sharing options...
harry yarnell Posted November 8, 2017 Topic Author Share Posted November 8, 2017 Got it out via the 1/2 open headlight door. Then out from under. Now, NONE of the local parts houses have a 890 bulb. Pisser. Link to comment Share on other sites More sharing options...
Frogware Posted November 8, 2017 Share Posted November 8, 2017 Got it out via the 1/2 open headlight door. Then out from under. Now, NONE of the local parts houses have a 890 bulb. Pisser. Yeah I ended up ordering from eBay but only after checking the Reatta Store, but I guess they don't have any in stock. Here's a link to the guy they are OEM and at a fair price; and fast shipping. https://www.ebay.com/itm/GE-890-27w-12-8v-T3-25-PG13-Base-Automotive-Bulb-SET-OF-2/322494445000?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Link to comment Share on other sites More sharing options...
ski.dive Posted November 8, 2017 Share Posted November 8, 2017 Yeah I ended up ordering from eBay but only after checking the Reatta Store, but I guess they don't have any in stock. Here's a link to the guy they are OEM and at a fair price; and fast shipping. https://www.ebay.com/itm/GE-890-27w-12-8v-T3-25-PG13-Base-Automotive-Bulb-SET-OF-2/322494445000?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 HELL!!!!=Even the light bulbs for the Reatta are hard to find...lol :) Link to comment Share on other sites More sharing options...
retired mechanic74 Posted November 9, 2017 Share Posted November 9, 2017 So far my lights are working fine but if a bulb goes out I plan to change the socket and use 1157 bulbs like most of the rest of the GM line uses. Not sure if the replacement socket will fit the lens but, I'll find out when a bulb goes bad and let you guys know. Link to comment Share on other sites More sharing options...
2seater Posted November 9, 2017 Share Posted November 9, 2017 So far my lights are working fine but if a bulb goes out I plan to change the socket and use 1157 bulbs like most of the rest of the GM line uses. Not sure if the replacement socket will fit the lens but, I'll find out when a bulb goes bad and let you guys know. The front turn signal circuit isn't a simple 12v with a flasher. It uses a higher power bulb with a voltage reducer to match the color and brightness of the small 194's when in parking light mode. I'm not sure why GM went to the trouble when a dual filament bulb would likely work as well, but it may require more real estate than available? Link to comment Share on other sites More sharing options...
retired mechanic74 Posted November 9, 2017 Share Posted November 9, 2017 The front turn signal circuit isn't a simple 12v with a flasher. It uses a higher power bulb with a voltage reducer to match the color and brightness of the small 194's when in parking light mode. I'm not sure why GM went to the trouble when a dual filament bulb would likely work as well, but it may require more real estate than available? As long as the socket will fit the lens I can deal with the rest. I know that the flasher is a module but if need be I will change it over to a flasher and get rid of the module and let you guys know how I did it just in case you are confronted with the same problem. Link to comment Share on other sites More sharing options...
harry yarnell Posted November 9, 2017 Topic Author Share Posted November 9, 2017 Thanks Skydive for the e-bay link. 2-890 bulbs for $10 and free shipping. Click send. Link to comment Share on other sites More sharing options...
