Posti Posted November 13, 2016 Share Posted November 13, 2016 The power windows on my 1989 Reatta coupe do not work at all. The cigarette lighter socket is also dead. Is there a fuse that controls both of these? I don't have an owner's manual or shop manual yet - both have been ordered. Thanks for any help! Link to comment Share on other sites More sharing options...
Ronnie Posted November 13, 2016 Share Posted November 13, 2016 It will be easier to troubleshoot the windows with the service manual. You could try replacing breaker #25 marked RAP/Horn/WDO that powers the windows but there are other things that could cause a problem as well, like relays and switches or possibly bad wire splices under the seats. Wire Splice Repair Link to comment Share on other sites More sharing options...
Posti Posted November 19, 2016 Topic Author Share Posted November 19, 2016 As a follow-on, I discovered that the windows work fine - the switch is worn and you have to depress the buttons down further to make contact. I'll pick up another when I can and look at using the rebuilding process I've seen on this site on the worst of the two. Link to comment Share on other sites More sharing options...
