Posti Posted November 13, 2016 Share Posted November 13, 2016 The right headlight on my 1989 Reatta coupe does not come up unless someone provides a slight lift. Then it pops right up, and lowers with no issues. Would this be the bushings, rather than a problem with the motor pivot arm? Thanks! Link to comment Share on other sites More sharing options...
DAVES89 Posted November 13, 2016 Share Posted November 13, 2016 Sounds like you have a crank arm issue. There are a number of vendors who sell them. Check Ronnie's store I think they are listed there. Link to comment Share on other sites More sharing options...
Ronnie Posted November 13, 2016 Share Posted November 13, 2016 When I got my Reatta the lights were having the same problem. Your best bet is to get a headlight repair kit for each headlight. The bushings in the gearbox are sure to be bad if they have never been changed. In most cases the crankarm will have the hole rounded out where it fits on the gearbox shaft (see photo). That was the case with my headlight motors too. Instructions for rebuilding the headlight motors will come with the kit. There are also instructions for removing the headlight assembly here. Link to comment Share on other sites More sharing options...
Posti Posted November 13, 2016 Topic Author Share Posted November 13, 2016 Thanks for the reply! Theya re sold out of the repair kit at the moment. I'll look for other sources. Link to comment Share on other sites More sharing options...
Ronnie Posted November 13, 2016 Share Posted November 13, 2016 The Reatta Specialty Parts Headlight kits should be back in stock soon but if you are in a hurry there are other kits for sale. I recommended this one because I used it on my car with good results. Link to comment Share on other sites More sharing options...
AZ Ron Posted November 14, 2016 Share Posted November 14, 2016 Try some lubrication first on the pivot points. Worked for me until it started to get colder at night. A rebuild is on my list too. :P :P Link to comment Share on other sites More sharing options...
