ski.dive Posted September 21, 2017 Share Posted September 21, 2017 Found a newly wrecked Reatta at the Junk Yard today. I tried to remove the accumulator ball, but it would NOT budge. How do I remove a stuck Accumulator ball? Link to comment Share on other sites More sharing options...
Ronnie Posted September 21, 2017 Share Posted September 21, 2017 When I got my Reatta the ball was really hard to remove. I used the Allen wrench and a strap style oil filter wrench to turn it while having a friend hold the pump with a large pair of channel locks to prevent putting to much torque on the bolt that attaches the pump to the master cylinder. Link to comment Share on other sites More sharing options...
DAVES89 Posted September 21, 2017 Share Posted September 21, 2017 Today when 2seater and I were testing some pressure switches and balls we ran into some tough ones that did not want to come off. What I did was get my battery powered impact wrench and then used the allen wrench socket. Same for the pressure switches using my Teves pressure switch socket. Worked like a dream. Link to comment Share on other sites More sharing options...
AZ Ron Posted September 22, 2017 Share Posted September 22, 2017 Small cheater bar on the allen wrench's long side. I put a block of wood next to the pump to keep it from turning. Link to comment Share on other sites More sharing options...
retired mechanic74 Posted September 22, 2017 Share Posted September 22, 2017 Small cheater bar on the allen wrench's long side. I put a block of wood next to the pump to keep it from turning. Another way is to use a 3/8's drive 3/8 or 7/16 deepwell socket and an extension on the allen wrench. Link to comment Share on other sites More sharing options...
heygibb Posted September 25, 2017 Share Posted September 25, 2017 Small cheater bar on the allen wrench's long side. I put a block of wood next to the pump to keep it from turning. This is what I did. Slow and steady pressure on the cheater bar worked perfectly. Link to comment Share on other sites More sharing options...
