bkcamaro Posted September 13, 2017 Share Posted September 13, 2017 I changed a bunch of my gaskets two weeks ago and put it back together this last weekend after i got new injectors cause i broke a couple of mine trying to change the o-rings and stabbed my finger with my pick. Well now i have a coolant leak right behind the throttle body right where the tube next to the thermostat fits into the throttle body. i know pulling it apart i noticed it must be a press fit cause i see no 0-rings nor a flange for some sort of gasket to sit. I did try using the search bar and couldn't find anything under coolant leak Link to comment Share on other sites More sharing options...
DAVES89 Posted September 13, 2017 Share Posted September 13, 2017 2seater has a "fix" for this. I think what he did was use a pipe tap and a plug. The pipe is used to help in warm up, but is not functional to car operation. However here is the weasel, wait for Ronnie or 2seater as I don't know for sure. Link to comment Share on other sites More sharing options...
Ronnie Posted September 13, 2017 Share Posted September 13, 2017 I've never been down that road before with a 3800 so I can't offer any help. Link to comment Share on other sites More sharing options...
2seater Posted September 13, 2017 Share Posted September 13, 2017 Pretty sure it is a press fit without an o-ring. You could try something like Loctite on the pipe and let dry a while before refilling. I just eliminate those pipes by tapping the holes in the manifold and installing pipe plugs. I have never had any issues but my car is summer only. The FSM says it is to avoid icing in cool damp weather? I know they are a pain if you remove the throttle body regularly or use different ones as I do. Link to comment Share on other sites More sharing options...
bkcamaro Posted September 14, 2017 Topic Author Share Posted September 14, 2017 Pretty sure it is a press fit without an o-ring. You could try something like Loctite on the pipe and let dry a while before refilling. I just eliminate those pipes by tapping the holes in the manifold and installing pipe plugs. I have never had any issues but my car is summer only. The FSM says it is to avoid icing in cool damp weather? I know they are a pain if you remove the throttle body regularly or use different ones as I do. do you remember what size tap Link to comment Share on other sites More sharing options...
bkcamaro Posted September 14, 2017 Topic Author Share Posted September 14, 2017 What i might do and don't know if i will have enough room but cut the pipe shorter and put a barbed fitting on it and use a small piece of hose to connect it Link to comment Share on other sites More sharing options...
2seater Posted September 14, 2017 Share Posted September 14, 2017 do you remember what size tap 1/4"npt for the one on top and 3/8"npt for the lower one with the studs. Alternatively you can just make a blank plate for the lower one. Link to comment Share on other sites More sharing options...
