heygibb Posted August 17, 2017 Share Posted August 17, 2017 Since I'm in the middle of a blower motor repair/replacement project, I thought I would activate the blend door while I could see it operate. For _hits and grins, I made videos. The top video is AC, bottom is heater activated. Filmed in real time. They play back on my Chrome browser but not Firefox, so ymmv. http://embracingwonderland.blogspot.com/2017/08/reatta-related-revelations.html Link to comment Share on other sites More sharing options...
2seater Posted August 17, 2017 Share Posted August 17, 2017 I honestly didn't realize the door was visible with the blower removed? I believe that door is the outside air control which is oriented horizontally. The blend door has a vertical pivot, swings side to side and is located further to the passengers side. Link to comment Share on other sites More sharing options...
heygibb Posted August 17, 2017 Topic Author Share Posted August 17, 2017 That's what I get for assuming. Thanks for the clarification. When it reacted to the temp controls, I jumped to my conclusion. Link to comment Share on other sites More sharing options...
retired mechanic74 Posted August 25, 2017 Share Posted August 25, 2017 I honestly didn't realize the door was visible with the blower removed? I believe that door is the outside air control which is oriented horizontally. The blend door has a vertical pivot, swings side to side and is located further to the passengers side. .....Here's a hint that may be helpful. When ever you have the blower module or blower motor removed use a mirror and a light and you can see all the way to the far end of the passenger side of the heater plenum. It's a good way to tell if your evap is leaking. Link to comment Share on other sites More sharing options...
heygibb Posted August 25, 2017 Topic Author Share Posted August 25, 2017 I am doing a thorough cleaning of the plenum today, w/ mirror and lighting, using compressed air and vacuum. I'll look for any signs. Link to comment Share on other sites More sharing options...
Ronnie Posted August 29, 2017 Share Posted August 29, 2017 .....Here's a hint that may be helpful. When ever you have the blower module or blower motor removed use a mirror and a light and you can see all the way to the far end of the passenger side of the heater plenum. It's a good way to tell if your evap is leaking. That is also a good way to access the evaporator so you can clean it. Link to comment Share on other sites More sharing options...
