ski.dive Posted July 16, 2017 Share Posted July 16, 2017 I turn on my A/C everyday here in Florida. 1988 Reatta-How do I make my Radiator fan come on all the time when I turn on the car? In other words, when I turn my key on, I want the radiator fan to come on. Link to comment Share on other sites More sharing options...
retired mechanic74 Posted July 17, 2017 Share Posted July 17, 2017 It's tricky what you need to do is find the fan relay, ( relay box driverside under the hood by the headlite, there are two of them, one for rad. fan the other for A/C, ether one will work) with a test light find the ground wire (black in color) hard wire the ground and using the test light find a + wire controlled by the ign. switch. (good luck with that) Using the test light find the + wire on the relay cut that wire back far enough to connect the ign. wire to it, that should give you what you want, be careful NOTE: by doing this you will more then likely get a reoccurring code warning of a fan problem. Link to comment Share on other sites More sharing options...
