ski.dive Posted July 12, 2017 Share Posted July 12, 2017 Found a complete Reatta ABS system at the local junkyard Are there instructions on how to remove it easily [without damaging it ] from the 88 junk Reatta?? Link to comment Share on other sites More sharing options...
Ronnie Posted July 12, 2017 Share Posted July 12, 2017 Removing the entire master cylinder unit requires considerable work because the bolts that hold it on are under the dash. Since the master cylinder/ABS valves rarely go bad it is common to just grab the pump assembly, that includes the pressure switch and accumulator, by unplugging the electrical connectors and removing the one bolt (goes in from the side) that holds the assembly in place. You will also have to disconnect the hose or steel pipe that supplies fluid from the reservoir. Link to comment Share on other sites More sharing options...
AZ Ron Posted July 13, 2017 Share Posted July 13, 2017 While you are there please see if you can remove the rubber plug where the transmission dip stick goes into the transmission. I will purchase it from you and gladly pay postage. Mine is chewed up and leaking EDIT: I no longer need this part thanks to 2seater Link to comment Share on other sites More sharing options...
2seater Posted July 13, 2017 Share Posted July 13, 2017 While you are there please see if you can remove the rubber plug where the transmission dip stick goes into the transmission. I will purchase it from you and gladly pay postage. Mine is chewed up and leaking. From another member: http://www.rockauto.com/en/catalog/buick,1988,reatta,3.8l+231cid+v6,1019898,transmission-automatic,dipstick+seal,10970 Link to comment Share on other sites More sharing options...
DAVES89 Posted July 13, 2017 Share Posted July 13, 2017 The Teves system in 1988 had a running change. The early 1988 Reattas had a different brake line on the top of the unit then the later units and are not compatible. Look at yours and then look at the one in the yard. If you have a smart phone take a picture of yours and compare it. Do not think you can "convert" it because you cannot. Your only recourse is to swap out the entire unit, then keep that unit as a back up. Removal is not that easy. The best way is to remove the steering column. Then you will much easier access to the 4 nuts that hold the Teves unit in place on the fire wall. It has been some time since I did that project so I will let you figure it out. I believe you need 15mm socket and a swivel as well as a 10mm socket for the bolt that holds the steering column in the boot also located at the fire wall. There is a need for a 7mm [i believe] to remove the shifter connection on the column. Link to comment Share on other sites More sharing options...
