ski.dive Posted June 30, 2017 Share Posted June 30, 2017 1988 REATTA= I took the codes from the ALDL =According to the tutorial/troubleshooting guide instruction. I got two codes from the ALDL connector [ I did the test twice to make sure ] First code= 32 Second code= 48 According to these 2 codes: Please to tell me what I need to do to FIX my problem with my ABS YELLOW light STAYING ON. ~Thanks for any help. Link to comment Share on other sites More sharing options...
DAVES89 Posted June 30, 2017 Share Posted June 30, 2017 32 is an indication of a front wheel speed sensor going bad. Put the front of your car up on jack stands and do a visual check of the leads. One or both [one on each side of car] is frayed or cracked. That is most likely the source of your problem. If you have an ohm meter you can confirm the failure by testing the resistance. resistance of 800-1400 ohms is good. You can trace the lead from the wheel to the side of the wheel well and into the engine compartment. You will find a plug that disconnects by sqeezing on the "flats" of the connection and pulling the lead apart. Sounds tricky but if you look closely you will see what I mean and it is not tricky. I have extra leads that have been reconditioned to like new condition. They sell for $125.00 each delivered. If interested you can reach me at; lemke1044@aol.com Link to comment Share on other sites More sharing options...
