ski.dive Posted June 28, 2017 Share Posted June 28, 2017 Tell me= How do you take off the Bosch ABS main relay located in firewall by brake reservoir? I can't get it to pull out to test it.? Link to comment Share on other sites More sharing options...
Ronnie Posted June 29, 2017 Share Posted June 29, 2017 Welcome to the forum. The information ou need can be found here: Any tips on removing a relay? Link to comment Share on other sites More sharing options...
ski.dive Posted June 29, 2017 Topic Author Share Posted June 29, 2017 Ronnie===Thanks for the help. Link to comment Share on other sites More sharing options...
Ronnie Posted June 29, 2017 Share Posted June 29, 2017 The relays are held onto the tabs with a small detent that goes into the hole in the mounting tab (at least on my car). You can feel them click into place when you install them. The relays are removed by pulling them down while twisting the relay from side to side to work it off the tab. If it is stuck the best way I found to get it to come off is to use the handle of a hammer as a lever, wedged between the top of the relay and the metal crossbrace, and apply steady, controlled, downward force to the top of the relay while twisting the relay in a rotating fashion side to side. Any lever could probably be used but the rubber hammer was handy on my workbench and it fit the space the way I wanted it to. http://reattaowner.com/forum/attachment.php?aid=380[/img] Link to comment Share on other sites More sharing options...
DAVES89 Posted June 29, 2017 Share Posted June 29, 2017 Some day when I am motivated enough I am going to get the relays like AZRon got with the tabs on them and screw them into place. That seems like the easiest solution to me. Link to comment Share on other sites More sharing options...
