droid5977 Posted June 6, 2017 Share Posted June 6, 2017 Is there a way to re-calibrate the outside air temp reading? Mine always reads hotter than the actual temp. And, Are there any replacements available for the little rubber grommets that the door panel pins slide into? Mine have split over time and the pin tends to pop out when I close the door. Link to comment Share on other sites More sharing options...
