Where Is The Chime Module Located 1990
B29 Engineer
  • 2 weeks later...
it is located underneath the drivers side lower panel you must remove the dash bezel to remove the lower panel look straight up  to the left  you will see a black square box mounted with 2 screws remove it ,its not that easy,write down part # and see if you can find one,it is used in various gm models
