B29 Engineer Posted April 16, 2017 Share Posted April 16, 2017 1990 Reatta Stalls sometimes when letting of fuel 600 rpm as for a stop light ,all indicating gauges are normal, Will restart normaly. Engine does not stall when driving, only when letting off the fuel. Link to comment Share on other sites More sharing options...
Ronnie Posted April 16, 2017 Share Posted April 16, 2017 Welcome to the ROJ forum Richard! We hope you come back often. There are several things the could cause the engine to stall and then start right back up. To find your problem you should start by seeing what trouble codes are stored in the Engine Control Module (ECM). Here are instructions for doing that. Write down any codes you find and post them here. That might give us a clue to what is causing the problem. Since you say you engine isn't stalling as long as you're moving, I would suspect the Idle Air Controller (IAC) might be dirty or defective. It is what is responsible for maintaining the idle at the correct RPM. Here are instructions for removing it and cleaning it. IAC Cleaning Instructions If you have additional questions feel free to ask. Link to comment Share on other sites More sharing options...
AZ Ron Posted April 16, 2017 Share Posted April 16, 2017 The drivability section of my 88's factory service manual says this can be caused by an EGR valve that is sticking open. Once again, we needs codes in order to help. There are several YouTube videos on how to clean an EGR valve if you should need to try that. Link to comment Share on other sites More sharing options...
Ronnie Posted June 2, 2017 Share Posted June 2, 2017 Did any of this help fix your problem? Link to comment Share on other sites More sharing options...
