48Rubles Posted April 9, 2017 Share Posted April 9, 2017 I have looked everywhere, how do you fold down the front seats of 89 reatta? In order to get into back to clean. Thank you White 1989 Reatta Link to comment Share on other sites More sharing options...
AZ Ron Posted April 10, 2017 Share Posted April 10, 2017 In order to clean a stain in the rear carpet just behind the seats I simply use the switch to run the seat all the way forward. Mine is an 88 so it may differ but I am able to tip the seat back forward. There is no latching mechanism on mine. Link to comment Share on other sites More sharing options...
Ronnie Posted April 10, 2017 Share Posted April 10, 2017 I also have and '88 and the back of the seat just tilts forward when the car is sitting still. If I remember correctly it should lock in place when you hit the brakes while moving... kinda like a seat belt does. If yours won't tilt forward maybe that mechanism is stuck in the locked position. There is also a handle on the outside of the seat that will adjust how much the seat back is reclined in relation to the seat bottom. If it hasn't been used much it will probably be hard to get it to work properly. At least on my car it was. Link to comment Share on other sites More sharing options...
kdirk Posted April 10, 2017 Share Posted April 10, 2017 If you have the standard 6 way seats, there is a recline lever on the outboard side of the seat. Pull it up and set the seatback forward. On the 16 way optional seats, there is small switch lever on the outboard side of the seat to control the power operated recline function. Press it forward to move the seatback towards the from of the car. Link to comment Share on other sites More sharing options...
AZ Ron Posted April 10, 2017 Share Posted April 10, 2017 Sorry for the quad pics. Getting late here and time to get off the puter! Link to comment Share on other sites More sharing options...
