moosefuel Posted August 27 Share Posted August 27 In working on restoring my 1990 convertible, I noticed that the doors are "loose." I managed to pry it open gently at the bottom and remove one of the long, plastic fastening "nails." I also noticed that a couple are missing, probably from the last owner mucking around with the doors, or from the bottom of the door rubbing on the trim plastic when it opens (it needs to be adjusted a bit). Where can I find these plastic fasteners, or is there a good alternative that will be more robust? These ones seem worn out enough that they don't hold the panel on very well anymore. Link to comment Share on other sites More sharing options...
Ronnie Posted August 27 Share Posted August 27 I was able to purchase them at my local Lowes store. There is an assortment of them in drawers in the hardware section. 1 2 Link to comment Share on other sites More sharing options...
Please sign in to comment
