Tallicat Posted February 4 Share Posted February 4 Hey guys, having an issue with the heater fan not turning off when i turn the heater off, and even when I turn the car off. Tried pulling fuse #20 and it still ran. Had to disconnect battery. Seems there is a relay center under the hood but i am not sure where it is or if it controls the fan. Thanks in advance. Link to comment Share on other sites More sharing options...
Ronnie Posted February 4 Share Posted February 4 Common problem. Most of the time it's caused by a bad blower control module. 1 Link to comment Share on other sites More sharing options...
2seater Posted February 4 Share Posted February 4 (edited) Heater fan module is powered directly from the battery via a fusible link. Module is likely bad Edited February 4 by 2seater Link to comment Share on other sites More sharing options...
Tallicat Posted February 4 Topic Author Share Posted February 4 40 minutes ago, Ronnie said: Common problem. Most of the time it's caused by a bad blower control module. Thanks Ronnie, are there replacement instructions on this site? Link to comment Share on other sites More sharing options...
DAVES89 Posted February 4 Share Posted February 4 Yes. Just look at the "How to" on the top of the page... Link to comment Share on other sites More sharing options...
Tallicat Posted February 6 Topic Author Share Posted February 6 On 2/4/2024 at 3:05 PM, DAVES89 said: Yes. Just look at the "How to" on the top of the page... I'm looking under A?C and Heat and dont see anything on the blower control module. On 2/4/2024 at 1:50 PM, Ronnie said: Common problem. Most of the time it's caused by a bad blower control module. Thanks Ronnie, are there replacement instructions on this site? Link to comment Share on other sites More sharing options...
Ronnie Posted February 6 Share Posted February 6 2 hours ago, Tallicat said: Thanks Ronnie, are there replacement instructions on this site? No tutorial needed. Only three screws hold it on. I thought you would get an answer from the people you're discussing this problem with on Facebook, but since you didn't here is a link to the information you need. Ignition off but fan continues to run. - Reatta Owners Journal Forum - Reatta Owners Journal Forums 1 Link to comment Share on other sites More sharing options...
