zacreep Posted December 1, 2023 Share Posted December 1, 2023 I recently bought a 1989 Reatta, and so far its been treating me well, but I've had one recurring problem that I cant find the solution to. The car will always start first try when its cold, but after I drive around a while and it gets hot and I turn it off, it wont start again. The engine cranks and I can hear the fuel pump kick on when I move the ignition switch to the second position, but when I turn the key it just keeps cranking. Sometime it will start for a few seconds and then die again, even when I give it gas. Today I drove it a lot further and longer than I have before and then went to a drive thru where it stalled on me. This was the first time its ever stalled while running, usually it runs fine but will have trouble starting after being turned off. I cleaned my ICV because I heard it could be that, but that didn't seem to help. I have some codes I got from my diagnostic screen and maybe one of these would have something to do with it? E022 - Throttle Position Sensor Voltage Too Low E039 - TCC Circuit E042 - Ignition System B119 - Twilight Sentinel Photosensor Circuit Problem B448 - Very Low A/C Refrigerant Pressure B552 - BCM Memory Reset Indicator C553 - CRTC Memory Reset Indicator These are all the codes that I have. Has anyone else had this problem or similar? I'm guessing it would be the E042 code that would be most relevant? Link to comment Share on other sites More sharing options...
DAVES89 Posted December 1, 2023 Share Posted December 1, 2023 (edited) Sounds like the Ignition Control Module and coils. Look for green goo on the lower radiator hose which is an indication that the module is failing. Edited December 1, 2023 by DAVES89 1 Link to comment Share on other sites More sharing options...
2seater Posted December 1, 2023 Share Posted December 1, 2023 That's probably the lower hose😖 The other temperature culprit could be the crank sensor, but look for sticky goo between the halves of the coil pack and ignition module first. Link to comment Share on other sites More sharing options...
zacreep Posted December 2, 2023 Topic Author Share Posted December 2, 2023 20 hours ago, 2seater said: That's probably the lower hose😖 The other temperature culprit could be the crank sensor, but look for sticky goo between the halves of the coil pack and ignition module first. Just wondering since the other guy also told me to check for green goo on the radiator hose and that its most likely my ICM/Coils. You said its most likely the lower hose but I should check for goo between the halves of the coil pack, So is the goo coming from the coil pack and dripping down onto the radiator hose? and by the two halves do you mean like inbetween the ICM plate and coil pack where the connectors are? Thanks for your help. Link to comment Share on other sites More sharing options...
2seater Posted December 2, 2023 Share Posted December 2, 2023 Yes to all comments. The other guy is a friend of mine so the comment was a bit tongue in cheek. I should clarify that the sticky goo applies to the original Magnavox style ignition, where the coils are contained in one solid block. If you have the later Delco style ignition, with three individual coils, the goo comment does not apply and it is more likely the crank sensor is failing. Link to comment Share on other sites More sharing options...
Ronnie Posted December 2, 2023 Share Posted December 2, 2023 4 hours ago, zacreep said: So is the goo coming from the coil pack and dripping down onto the radiator hose? and by the two halves do you mean like inbetween the ICM plate and coil pack where the connectors are? The goo comes from inside the Ignition Control Module and drips down on the radiator hose. It will also get on the electrical connector sometimes. Red arrow shows what you are looking for. Second photo shows where it's coming from. 1 1 Link to comment Share on other sites More sharing options...
