Ohjai Posted November 14, 2023 Share Posted November 14, 2023 Fixed the antenna, the radio searches and finds stations but not audio out. I do not have a cassette to try. Checked two fuses, a 25Amp and a 15 Amp. Both good. Do I have a bad radio? or just bad power transistors and capacitors in the radio.? Jim Link to comment Share on other sites More sharing options...
Ronnie Posted November 14, 2023 Share Posted November 14, 2023 Did the radio play before the antenna went bad? Link to comment Share on other sites More sharing options...
Ohjai Posted November 15, 2023 Topic Author Share Posted November 15, 2023 I haven't been completely honest with you all. I got a 1992 Riviera Saturday, the antenna did not work, I took the one out of the Blue convertible that I just got back from Barney Eaton, put it in the Riviera. The radio seeks stations and locks on them, but there is not a peep or pop coming through the speakers. The radio is the U1H option that I understand is identical to the Reatta radio. Link to comment Share on other sites More sharing options...
rogold Posted November 15, 2023 Share Posted November 15, 2023 Just a hunch, have you checked that the antenna cable is plugged in to the radio module? I think I had this same problem on my 89, but it was a long time ago. 1 Link to comment Share on other sites More sharing options...
Ronnie Posted November 16, 2023 Share Posted November 16, 2023 On 11/14/2023 at 10:05 PM, Ohjai said: I got a 1992 Riviera Saturday, the antenna did not work, I took the one out of the Blue convertible that I just got back from Barney Eaton, put it in the Riviera. The radio seeks stations and locks on them, but there is not a peep or pop coming through the speakers. I don't know much about the '91 models and zero about Rivs. Is it possible the Riv has the optional Bose radio system that have separate amps? If so that amp could be bad. 1 Link to comment Share on other sites More sharing options...
ship Posted November 16, 2023 Share Posted November 16, 2023 7th generation Rivieras did offer a Bose radio system as an option, code U1G. 1 Link to comment Share on other sites More sharing options...
Ohjai Posted November 17, 2023 Topic Author Share Posted November 17, 2023 I have the standard system U1H 1 Link to comment Share on other sites More sharing options...
