Ohjai Posted October 30, 2023 Share Posted October 30, 2023 Not getting any heat in my 91, took out glove box and found air mix valve not moving. Checked Section C of manual and unable to find out how to trouble shoot it. I did find how to adjust the valve, but the control arm is not moving when I change temperatures. Jim Link to comment Share on other sites More sharing options...
2seater Posted October 30, 2023 Share Posted October 30, 2023 Programmer MOTOR, A/C Electric Temperature and Motor Control -15-71882 /16144370 | eBay The original part number for the blend door motor is 16050729, superseded by 16144370. The add above is eBay, $85. Also on Amazon is the GM part for almost double the money. A relatively recent thread about the same subject.Reatta no heat - Reatta Owners Journal Forum - Reatta Owners Journal Forums 1 Link to comment Share on other sites More sharing options...
Ohjai Posted October 31, 2023 Topic Author Share Posted October 31, 2023 I did a search on the air mix valve and did not get any hits. When a person does a search, it helps if he knows what he is searching for, and I am terrible when it comes to calling something the same thing twice. Short term memory is a problem. Link to comment Share on other sites More sharing options...
2seater Posted October 31, 2023 Share Posted October 31, 2023 10 hours ago, Ohjai said: I did a search on the air mix valve and did not get any hits. When a person does a search, it helps if he knows what he is searching for, and I am terrible when it comes to calling something the same thing twice. Short term memory is a problem. Yep, that is one of the weaknesses of searches on most forums. If you don't know what the key word is, or how the original post was phrased, it becomes a frustrating exercise. I had to cheat myself and search for my attachments to find one of the relevant threads😎 Incidentally, that part has increased in price quite a bit and you might do better to find a used climate controller since it must be removed to repair in any case. Jim Finn is a good source for tested used parts. 1 1 Link to comment Share on other sites More sharing options...
