89reattaWI Posted October 10, 2023 Share Posted October 10, 2023 hey i’m rebuilding a series 2 3800 and it’s on an engine stand so the pulley just spins of course. i just need some help on how i can stop the pulley from spinning so i can remove the bolt. i’m guessing there’s a tool or something i can borrow from a parts store? Link to comment Share on other sites More sharing options...
rogold Posted October 10, 2023 Share Posted October 10, 2023 You can pull a sparkplug out, then get some rope and feed it into the sparkplug hole. Now turn the pulley bolt counterclockwise slowly, it should stop when the piston in the cylinder pushes up the rope against the cylinder head. Now you should be able to get the bolt off. Once you get the dampner off reinstall the bolt and turn the crank enough to pull the rope out. no 1 2 Link to comment Share on other sites More sharing options...
2seater Posted October 10, 2023 Share Posted October 10, 2023 If the pan is off you can insert a bar in a crank throw or if the flexplate is installed on the rear it can be clamped or jammed. An impact is probably the best if available as it is easy to tip an engine stand over with a lot of torque on the bolt. I don't know if the Series 2 is similar to the LN3 in that department or not. 2 Link to comment Share on other sites More sharing options...
89reattaWI Posted October 10, 2023 Topic Author Share Posted October 10, 2023 Thanks guys I’m gonna try the rope method tonight after work since the pan is on and I’m not sure what I’d use to stop the flex plate. Link to comment Share on other sites More sharing options...
Ronnie Posted October 10, 2023 Share Posted October 10, 2023 1 hour ago, 89reattaWI said: Thanks guys I’m gonna try the rope method tonight after work since the pan is on and I’m not sure what I’d use to stop the flex plate. Be sure you do it with the piston on the compression stroke. It's possible to damage a valve if it's on the intake stroke. 2 Link to comment Share on other sites More sharing options...
89reattaWI Posted October 12, 2023 Topic Author Share Posted October 12, 2023 Thanks guys I managed to remove it and can go on with my rebuild. Incredibly stuck bolt and the pulley itself. 1 Link to comment Share on other sites More sharing options...
