ianhm Posted September 23, 2023 Share Posted September 23, 2023 https://drive.google.com/file/d/18BauaUfn7gi-91HXv5XpsPO44VqZDGh7/view?usp=drivesdk https://drive.google.com/file/d/1asMy335eOzh6Ykv8e6ebS-pSrqJ31CYz/view?usp=drivesdk so here are my issues and hopefully the link will work but I made videos Link to comment Share on other sites More sharing options...
Ronnie Posted September 23, 2023 Share Posted September 23, 2023 You posted a link to your Google drive and it requires access to view it. Please describe the problem you are having. Link to comment Share on other sites More sharing options...
ianhm Posted September 23, 2023 Topic Author Share Posted September 23, 2023 So I have a Reatta and the screen was fine the day I got it until later in the day. It’s just shut off. The touch screen part still works but the crt isn’t projecting. So I came here to see what others have said. I saw the rap issue that some are having but all my rap features work and I see the button light up on radio when I turn the car off. It worked for about 10 sec yesterday and today first turnover of the engine. Then now will not come back on. Link to comment Share on other sites More sharing options...
Ronnie Posted September 23, 2023 Share Posted September 23, 2023 Does the instrument panel work as it should? If not, make sure the fog lights are off by pushing the button near the shifter, then try sliding the dimmer on the headlight switch to the right. Let us know if that makes a difference. Link to comment Share on other sites More sharing options...
ianhm Posted September 23, 2023 Topic Author Share Posted September 23, 2023 Yhea so I had to jump it. the dimmer switch was all the way to the right by the headlight. The radio is currently not on inning and when we jumped it the screen was working with a little noise (occasional line’s jumping) and it has been sitting since I got home. Just went to start it up screen was on for 3 sec then went right off Link to comment Share on other sites More sharing options...
rogold Posted September 23, 2023 Share Posted September 23, 2023 My CRT display always goes a little fuzzy when I have my old battery charger hooked up. I suspect there is a little ripple on the 12VDC output of the battery charger. Link to comment Share on other sites More sharing options...
ianhm Posted September 24, 2023 Topic Author Share Posted September 24, 2023 So far today the screen has come on for 1 min then is off. Looks like previous owner may have done some self wiring but we’ll see Link to comment Share on other sites More sharing options...
ianhm Posted September 28, 2023 Topic Author Share Posted September 28, 2023 Today the screen has randomly turned on and is working and staying on. I assume that when I turn the car off it will also probably not come back on today be let’s see Link to comment Share on other sites More sharing options...
