Top Down Posted July 6, 2023 Share Posted July 6, 2023 I have a gremlin somewhere. Instrument panel lights work fine EXCEPT when I turn on the headlights. The headlights work just fine but the instrument panel lights go somewhere into the dark like a mystery novel. Is there a detective in the house..........? Link to comment Share on other sites More sharing options...
Ronnie Posted July 6, 2023 Share Posted July 6, 2023 Have you checked the dimmer slider on the headlight switch to see it has been slid to the left? 1 Link to comment Share on other sites More sharing options...
Top Down Posted July 6, 2023 Topic Author Share Posted July 6, 2023 The dimmer slider is always set in the mid range..........I never move it to avoid snapping it off. I am ready for the next chapter of the mystery novel............? Link to comment Share on other sites More sharing options...
Ronnie Posted July 6, 2023 Share Posted July 6, 2023 Reatta Owners Journal - Instrument Panel Lights - Troubleshooting 1 Link to comment Share on other sites More sharing options...
DAVES89 Posted July 6, 2023 Share Posted July 6, 2023 Is it the '89 or the '90. I have an intermittent problem with mine on the '89 and I believe it is in the console fog/running light switch. I just turn it on and off several times and it comes back on. But for me it is when I go from bights to dims on the headlights that the pods [wipers/Headlight switches go out]. Hasn't happened in months though. Link to comment Share on other sites More sharing options...
Top Down Posted July 8, 2023 Topic Author Share Posted July 8, 2023 Ronnie was, in fact, correct in that the panel light adjustment was the issue. The '90 Reatta has a lever type adjustment for the panel lights. The lever is a flimsy piece of plastic which requires that it be pushed inward and then slide to the desired position. You need to be light figured to avoid breaking this lever. Evidently the lever was not seated properly which prevented the instrument lights to come on when the headlights were activated. I also noted that the lever needed to be positioned to the right of the scale mid-point in order for proper operation. Case closed. 1 1 Link to comment Share on other sites More sharing options...
