2seater Posted June 13, 2023 Share Posted June 13, 2023 I would need to go back over the saving from the crusher thread to confirm, but I think we wound up replacing the ECM because of O2 and open loop issues. The clue was notations in the history someone was keeping in the car that the O2 was changed multiple times making it likely they were chasing a problem of some kind. 1 Link to comment Share on other sites More sharing options...
2seater Posted June 13, 2023 Share Posted June 13, 2023 I did look through that three year old thread and around page four or five, we did in fact change the ECM. The O2 sensor came to life and closed loop engaged. I cannot tell you if one or the other would cause it to stay open loop, but it did require a donor ECM to get everything to work properly. 1 Link to comment Share on other sites More sharing options...
drdelsol Posted June 20, 2023 Topic Author Share Posted June 20, 2023 (edited) well,I have O2 sensor data again. Just got done replacing the ECM. Looked like it had been replaced before. My wife said a couple weeks ago she had a feeling it was the computer. We will be married 36 years tomorrow so at least she finally gets her car back. Its running perfect. Thanks so much for all the help. Edited June 20, 2023 by drdelsol 2 1 Link to comment Share on other sites More sharing options...
Ronnie Posted June 20, 2023 Share Posted June 20, 2023 Thanks for following up and letting us know what fixed it! 1 2 Link to comment Share on other sites More sharing options...
drdelsol Posted June 20, 2023 Topic Author Share Posted June 20, 2023 Sigh. Lasted one day. Now getting b334. Ac , speedomoter, tach not working . No e data. Ill start a new thread for this one sometime Link to comment Share on other sites More sharing options...
Ronnie Posted June 21, 2023 Share Posted June 21, 2023 41 minutes ago, drdelsol said: Sigh. Lasted one day. Now getting b334. Ac , speedomoter, tach not working . No e data. Ill start a new thread for this one sometime Sorry to hear that. I've never heard of anyone getting that code. Below is the troubleshooting flow chart for an '89. I think it is probably the same as your '90. Maybe it's just a bad connection. Hope it helps. Link to comment Share on other sites More sharing options...
Ohjai Posted June 22, 2023 Share Posted June 22, 2023 Ronnie posed the info for an 89, this is from the 91 manual. Hope it helps. Link to comment Share on other sites More sharing options...
drdelsol Posted June 24, 2023 Topic Author Share Posted June 24, 2023 I switched them a couple of times today. If i use the old computer I don' t get the B334 code but I also don't get the O2 sensor data and it dies. If I use the new,refurbished one, it runs but I get the B334 and no Rpm, speed, temp or ac. Did the connections several times and only get the E data loss with new computer so probably the new ECM and not the wiring. Guess I'll try another ECM Link to comment Share on other sites More sharing options...
2seater Posted June 24, 2023 Share Posted June 24, 2023 When mine did that last year, it was the Prom itself that had the issue. It was in a thread about the spare parts LN3 plus a supercharger. It had me chasing my tail, switching ECM's, switching Proms where it would settle down only to rear its ugliness again. The Prom itself had to be changed. 1 Link to comment Share on other sites More sharing options...
Ronnie Posted June 24, 2023 Share Posted June 24, 2023 I split the discussion about coolant temperature off and put it in a new topic. Hope I didn't mess up this topic discussion by doing that. 1 Link to comment Share on other sites More sharing options...
drdelsol Posted June 30, 2023 Topic Author Share Posted June 30, 2023 Ok. Just put in the second reconditioned ECM from Rockauto. Everything works now. We have AC, all the dash works and great idle. Took it for a longer test drive this time and no problems. Going to try to send the first ECM back. Thanks for all the help. Really mean it. 2 Link to comment Share on other sites More sharing options...
