Danpatters583 Posted June 23, 2022 Share Posted June 23, 2022 I haveva 1990. I want to help increase sounds and a slight bit of Performance. I plan on removing the flash on the exhaust manifolds as well as a modern cat and better muffler. I was curious though about the 91 reatta exhaust. I was reading that on a 90 it's 2.25" and the 91 is a 2.5". If I were to find the exhaust off of a 91 will it bolt to the 90? Or is there some kind of clearance issues? I was also thinking about having a shop build a 2.5" set up for me. Link to comment Share on other sites More sharing options...
2seater Posted June 23, 2022 Share Posted June 23, 2022 The larger diameter will bolt directly to the existing rear exhaust manifold. The piping may be larger but the inlet is the same. I have a '95 tailpipe that came with my donor engine and the bolt pattern matches. Just a suggestion, but in this case, I would keep the stock downpipe from the manifold, which has two nice smooth gentle bends, install a 2.5" replacement cat, even a cheap Walker universal will work fine, and then do a 2.5" cat back if you desire. Doubtful it will be worth the effort to increase size unless you are otherwise boosting/force feeding the engine. I have flowbenched the stock and aftermarket Walker universal cat and the aftermarket flows almost 50% more at the same pressure. I run that cat on my turbocharged engine. I do have a Dynomax straight through stainless steel muffler but the turbocharger takes the edge off of the sound a little. Removing the restriction in the rear manifold outlet is a good idea. The rest of the manifold interior is okay as is. Link to comment Share on other sites More sharing options...
Padgett Posted June 23, 2022 Share Posted June 23, 2022 BTW, unless you have a really hot cam, a single exhaust is best for scavenging a 6. Link to comment Share on other sites More sharing options...
Danpatters583 Posted June 23, 2022 Topic Author Share Posted June 23, 2022 Yeah I was just going to run a single pipe. I was thinking if I can find a series one super charger set up that I would out it in the car and that's why I wash thinking of going up a size. 17 hours ago, 2seater said: The larger diameter will bolt directly to the existing rear exhaust manifold. The piping may be larger but the inlet is the same. I have a '95 tailpipe that came with my donor engine and the bolt pattern matches. Just a suggestion, but in this case, I would keep the stock downpipe from the manifold, which has two nice smooth gentle bends, install a 2.5" replacement cat, even a cheap Walker universal will work fine, and then do a 2.5" cat back if you desire. Doubtful it will be worth the effort to increase size unless you are otherwise boosting/force feeding the engine. I have flowbenched the stock and aftermarket Walker universal cat and the aftermarket flows almost 50% more at the same pressure. I run that cat on my turbocharged engine. I do have a Dynomax straight through stainless steel muffler but the turbocharger takes the edge off of the sound a little. Removing the restriction in the rear manifold outlet is a good idea. The rest of the manifold interior is okay as is. I was thinking about doing a high flow cat to help more. There was one for like 59 bucks. Haven't really decided what I want to do yet. But thanks for all the advice! Link to comment Share on other sites More sharing options...
