john d Posted December 22, 2021 Share Posted December 22, 2021 Good morning . Looking for a blend door acuator for my 1990 convertible. Â Thanks Link to comment Share on other sites More sharing options...
2seater Posted December 22, 2021 Share Posted December 22, 2021 Are you asking about this part? The only source I can think of is from a junk climate programmer. Try one of the vendors listed at the head of the page. Â Â Link to comment Share on other sites More sharing options...
DAVES89 Posted December 22, 2021 Share Posted December 22, 2021 Never had an actuator go bad on any of my Reattas. The arm on top of the actuator is a known to fail item. 1 Link to comment Share on other sites More sharing options...
2seater Posted December 22, 2021 Share Posted December 22, 2021 8 minutes ago, DAVES89 said: Never had an actuator go bad on any of my Reattas. The arm on top of the actuator is a known to fail item. The clip on the arm at the flapper door is plastic and it breaks so the rod is no longer effective. Partially hidden by the BCM forward of the glovebox Link to comment Share on other sites More sharing options...
john d Posted December 22, 2021 Topic Author Share Posted December 22, 2021 Thank You for replies This is what I'm looking for. Link to comment Share on other sites More sharing options...
john d Posted December 22, 2021 Topic Author Share Posted December 22, 2021 I see that 2 seater has the motor out of the complete unit. My understanding is if you can move the arm, which I can, the motor is no good. and yes that is what I'm looking for. I'm in the process of calling junk yards. They will of course only sell complete unit. Appreciate any help, as always. Link to comment Share on other sites More sharing options...
Philbo Posted December 22, 2021 Share Posted December 22, 2021 Vendors that @2seater mentioned: https://reattaowner.com/roj/repair-information/reatta-parts-vendors  You could also try east coast reatta, but their prices can be steep.  Could try LKQ as well. Link to comment Share on other sites More sharing options...
Padgett Posted December 22, 2021 Share Posted December 22, 2021 Never had a motor fail, have had a blend door stuck shut and had to adjust the arm a bit shorter. Link to comment Share on other sites More sharing options...
2seater Posted December 22, 2021 Share Posted December 22, 2021 I have a disassembled programmer and I just checked the arm on the motor. It does not move, so I believe you are correct about the motor, unless the arm slips on the steel shaft of the motor?? I don't know the provenance of this programmer🤨 It is either a replacement I purchased some time ago or it is the one from my 89 parts car? Essentially I don't remember what I intended to do with it. PM me if you strike out through a vendor. Link to comment Share on other sites More sharing options...
john d Posted December 23, 2021 Topic Author Share Posted December 23, 2021 2 seater. Will let you know how I make out with vendors. Perhaps a nine volt transistor battery to the motor you have could check its function. Link to comment Share on other sites More sharing options...
2seater Posted December 23, 2021 Share Posted December 23, 2021 2 hours ago, john d said: 2 seater. Will let you know how I make out with vendors. Perhaps a nine volt transistor battery to the motor you have could check its function. Just checked it with a 12vdc power supply and it works in both directions. If you have the HVAC programmer out of the car, the motor assembly simply unplugs and a couple of screws hold it in. The brown and orange wires go to the motor, the other three; red, white and blue, in this case, are for the position encoder to tell the BCM the position of the arm and aren't needed to test the motor. 1 Link to comment Share on other sites More sharing options...
john d Posted December 23, 2021 Topic Author Share Posted December 23, 2021 2 seater. Appreciate all your help. I'll take the motor if you are interested in selling it. Please reach out to me at processing713@gmail.com or 786 493 7689. Link to comment Share on other sites More sharing options...
Padgett Posted December 24, 2021 Share Posted December 24, 2021 BTW AFAIR the servo motor is a worm gear that cannot be driven by the output. Link to comment Share on other sites More sharing options...
2seater Posted January 16, 2022 Share Posted January 16, 2022 On 12/23/2021 at 8:17 PM, Padgett said: BTW AFAIR the servo motor is a worm gear that cannot be driven by the output. I believe you are 100% on that. I sent the motor to the OP and after inquiring about the result was informed it fixed his issue. I suggested sharing that with the forum but after a week, no response.😕 Link to comment Share on other sites More sharing options...
Ron Walker Posted January 24, 2022 Share Posted January 24, 2022 Its a good thing I can look up acronyms on the internet after racking my brain when the guess comes up empty or doesn't make sense. 🙂 Link to comment Share on other sites More sharing options...
DAVES89 Posted January 24, 2022 Share Posted January 24, 2022 BTW =By The Way AFAIR= As Far As I Remember OP= Original Poster 1 Link to comment Share on other sites More sharing options...
Padgett Posted January 24, 2022 Share Posted January 24, 2022 Well is here and then there is, and I have some: IMNSHO (in my not so humble opinion). Ant then there is New Old Stock, New Old Reproduction Stock, New Off The Shelf (never worked)., and finally the end all GPAR ( Go Pound A Rock). 2 Link to comment Share on other sites More sharing options...
