Reatta 89 Posted October 17, 2021 Share Posted October 17, 2021 Where can I find a replacement fuel sending unit. Link to comment Share on other sites More sharing options...
Reatta 89 Posted October 17, 2021 Topic Author Share Posted October 17, 2021 Sorry it is for a black 89 reatta. Link to comment Share on other sites More sharing options...
Padgett Posted October 18, 2021 Share Posted October 18, 2021 Sorry but they have not been available new for some time but may be available from a vendor. Do you need one because of rust or because it does not work ? If metal is in good shape it may be possible to remove the gutz from a different but similar unit and build a replacement. Link to comment Share on other sites More sharing options...
DAVES89 Posted October 18, 2021 Share Posted October 18, 2021 Dorman #692-102 is a direct replacement. However when you fill the car it will show full and then by the time the indicator shows 2 gallons left you will have about 6 left. 1 Link to comment Share on other sites More sharing options...
DAVES89 Posted October 18, 2021 Share Posted October 18, 2021 When I had my sending unit replaced the electrical contact was loose. I am sure you could tighten it up, but I opted to replace mine. It's in the Red and I have put on about 5000-10000 since it was replaced. Link to comment Share on other sites More sharing options...
Reatta 89 Posted October 18, 2021 Topic Author Share Posted October 18, 2021 Thank you so much for the advice. Link to comment Share on other sites More sharing options...
Padgett Posted October 18, 2021 Share Posted October 18, 2021 Good news that a replacement is available. 1 Link to comment Share on other sites More sharing options...
Reatta 89 Posted October 31, 2021 Topic Author Share Posted October 31, 2021 One more thing does anybody know where to find the two rubber hoses that go from the gas tank to the fuel lines. Link to comment Share on other sites More sharing options...
Ron Walker Posted October 31, 2021 Share Posted October 31, 2021 Go to the heading above under "More Info." Page down to Reatta Parts Vendors. First one shown, Jim Finn, may be of assistance. Lots of us have contacted him for parts. He usually responds quickly and is otherwise helpful. Link to comment Share on other sites More sharing options...
Reatta 89 Posted October 31, 2021 Topic Author Share Posted October 31, 2021 Thanks Link to comment Share on other sites More sharing options...
Philbo Posted November 4, 2021 Share Posted November 4, 2021 On 10/17/2021 at 7:12 PM, Reatta 89 said: Sorry it is for a black 89 reatta. Just be carful, i heard the ones for the red reattas don't work in the black ones. I jest of course. Good luck with it! 1 Link to comment Share on other sites More sharing options...
Reatta 89 Posted November 4, 2021 Topic Author Share Posted November 4, 2021 Fuel problem solved Jim Finn saved me he had the parts I needed now I can put the reatta back together. 3 1 Link to comment Share on other sites More sharing options...
Please sign in to comment
You will be able to leave a comment after signing in
