rogold Posted October 18, 2021 Share Posted October 18, 2021 I would change the regulator, especially if its the original. Even if its not leaking internally, the spring inside may be getting tired, causing the lower pressure. And its easy to replace. 1 1 Link to comment Share on other sites More sharing options...
Padgett Posted October 18, 2021 Share Posted October 18, 2021 and then you would have a spare that does not take up much space. 1 Link to comment Share on other sites More sharing options...
2seater Posted October 18, 2021 Share Posted October 18, 2021 I have never seen a regulator fail except if the diaphragm leaks, and that was only once. Yours is performing properly, the absolute numbers can have a slight variation just due to the quality or accuracy of the gauge. As long as the Fuel Integrator and Block Learn are in the target range over normal driving conditions, you are giving the engine what it needs and the ECM is happy. Just my $.02 1 Link to comment Share on other sites More sharing options...
