MarkN Posted July 13, 2021 Share Posted July 13, 2021 I get an occasional SES light a few minutes after start, then extinguishes about 5 minutes later. I ran the on-board code check and get E043h. Checking the manual indicates a knock sensor fault. (The engine always runs fine, though). So, has anyone changed this sensor? I finally found the silly thing, essentially above the oil pressure sensor, but the service manual was zero help. (YouTube showed me where a Series 1 3800 sensor resides). Seems pretty straightforward. Link to comment Share on other sites More sharing options...
2seater Posted July 13, 2021 Share Posted July 13, 2021 (edited) It is relatively simple to change except for location. The wiring connector is a squeeze type where you need to pinch the sides inward to release. It just unscrews from the block and is 1/4” npt. Do not overtighten when installing or it may compromise the sensor sensitivity. Have you checked knock sensor activity in diagnostics? Immediately after starting go to diagnostics ED17, and watch the knock counts during the time this sometimes occurs. There should be no activity while running at idle or low load. If the number is stable, rap sharply on an engine bracket, like the lifting eye on the right rear, and see if the knock counts increase as it should. Edited July 13, 2021 by 2seater 1 Link to comment Share on other sites More sharing options...
