bghere Posted June 19, 2021 Share Posted June 19, 2021 I last had a question in regards to replacing ignition, well I found someone to do that, NOW I have a vampire draining the battery! touch screen show door open? while the door is shut. I went out to the garage, hearing the dinging of the door, went to start and the battery was dead, toke it to be tested, tested OK, full charge. put it back in, all good for two days, and happened again. Any ideas? Link to comment Share on other sites More sharing options...
Ronnie Posted June 19, 2021 Share Posted June 19, 2021 Sounds like the interior lights are staying on because the BCM thinks a door is open. Have you checked that? 1 Link to comment Share on other sites More sharing options...
jon L Posted June 20, 2021 Share Posted June 20, 2021 Or, you interior lights could be on because the switch on the light switch is turned on. 1 Link to comment Share on other sites More sharing options...
Ronnie Posted June 20, 2021 Share Posted June 20, 2021 16 hours ago, jon L said: Or, you interior lights could be on because the switch on the light switch is turned on. Would that account for the "touch screen show door open? while the door is shut." he reported? Maybe it could. I've never had a similar problem. Link to comment Share on other sites More sharing options...
2seater Posted June 20, 2021 Share Posted June 20, 2021 14 minutes ago, Ronnie said: Would that account for the "touch screen show door open? while the door is shut." he reported? Maybe it could. I've never had a similar problem. Oops, missed that myself. 😖 1 Link to comment Share on other sites More sharing options...
