dash acts strange
steve0
my dash will go completely blank after car sets....no error or code....if i disconnect the negative battery term for 10-15 minutes it will start working.....car was setting for 3-4 days while i replaced headlight switch dash was black again so i put the battery tender on it....apx 45 minutes later the dash starting working again.....never had a starting issue with battery...was replaced 5 years ago....could this be the problem ?
Do the diagnostics work, is it just the speedo/tach/gauge module or everything ? 1990s are known to have issues.
it is everything in the dash cluster....radio and a/c controlls all light uo
Usually it's just the panel with the gauges on it. Radio and AC are separate modules.
https://i.ebayimg.com/images/g/~xUAAOSwQpZgJG-p/s-l1600.jpg
Sounds to me like a bad connection either in the dash or in the module. With engine running if you shine a flashlight on the dash, can you see the gauges ?
