This stream auto-updates
  1. Yesterday
  2. sarookha
    Oil Pan Gasket Fiasco
    I usually use Google to search this forum (and others), by adding ::reattaowners.com (or whatever site you want to search) after my query. That forces Google to prioritize hits from the site you are interested in. e.g. Oil pan gasket ::reattaowners.com brings up two threads
  3. Ronnie
    embarrassing brakes
    Your brakes may be worn down to where the "squealers" are touching the rotor when you apply the brakes. The squealers are attached to the pads and warn you when the brake pads worn enough that they need replacing.
  4. WHman
    embarrassing brakes
    I inspected my brakes and they seemed to me okay, the pads are nice and flat, seem a few months old at least but they still got some life left in them. however im not well acquainted with these vehicles so even if theyre still good should i replace them? or maybe i should look at the hardware itself as ive noticed my brakes do not have those metal clips on them like are present in most vehicles. the calipers and rotors are like new as well. Thanks for all the suggestions and future support.
  5. Last week
  6. DAVES89
    embarrassing brakes
    Sounds like an inspection of worn brake pads to me. The intermittent abs yellow warning light could indicate a worn abs lead. You should ceck the lead for fraying or cracking. It is the lead at each wheel that is not a brake line.
  7. So recently i purchased an 88 reatta and since purchase it has had a strange grinding sound when braking or going around 5-15 MPH that is very obnoxious and sounds detrimental to the car itself. however i have had some trouble finding any information about this. Also, maybe related or not i have a yellow ABS light on intermittently when braking and i also lose about .1-.3 voltage when I apply the brakes, these may be normal but i figured id include these in here incase it’s pertinent information. I was hoping someone could point me in a direction to someone else’s post or they could give me some information about what to do. I’ll take a video of the brakes working later today. Thanks.
  8. Ronnie
    Break fluid leak
    Odd that a rubber plug would be used to stop brake fluid from coming out. I'm wondering if the rubber is intended to be a dust plug for something else that is supposed to seal the brake fluid behind it. If all you need is a rubber plug, one of the "Christmas tree" style push pins like hold inner fender panels and such on might work. My local Autozone has a big selection of styles and sizes. I had to get some for my mustang to hold the trunk carpet in place when I replaced the rear shock absorbers.
  9. 2seater
    Break fluid leak
    It doesn't look too sophisticated so I would think it would be a great candidate for someone with a 3D printer since you have a good sample?
  10. Clay-Goose-Davis
    Break fluid leak
    I swapped the rubber plug from one to the other and it stopped the leak. I just have to find another or something that will work
  11. rogold
    Break fluid leak
    I think this is a better pic, of course not in stock. Maybe try Ebay. ACDelco 18020180 Valve - Walmart.com
  12. Clay-Goose-Davis
    Break fluid leak
    I pulled this one off of the other proportioning valve. It is made of soft rubber. It has identification markers BAF and 56. I wonder if there is any way to get another one of these.
  13. Like most things, it sometimes makes no sense. People are repairing, or at least trying to repair, Reatta's that should be parted out and others are just the opposite. Seemingly decent cars that deserve some TLC are being scavenged and discarded. Definitely well under $1k for a running parts car, much less than that for a lawn ornament, unless of course it has exactly the stuff you need. Mixing and matching colors, inside and out, or model years with incompatible content really limits the usefulness.
  14. 2seater
    Break fluid leak
    It sounds odd to be missing a part unless it had been worked on recently?? I have no knowledge of the Bosch system and if you trust this shop, what do they recommend?
  15. Clay-Goose-Davis
    Suspension and Hub replacement
    The wheel bearings were in good shape. I’ve replaced the output seals, axles, sway bar bushings and end links, inner and outer tie rods, and ball joints. All on both sides. Everything went ok besides the ball joints I selected being too tight a fit and rubbing on the passenger side. There was only one AC Delco ball joint left on Rock Auto so lazily I went with the Mevotech ones rather than trying to find and order another one. Thankfully I have another passenger side axle I bought from Jim Finn that I’ll swap this damaged one out with. If anyone has replaced their ball joints, what part did you use?
  16. Clay-Goose-Davis
    Break fluid leak
    Went in for an alignment and had Buttita Auto take a look. They say it’s missing a plug and it’s leaking from the side where the line doesn’t connect. Does this sound right?
  17. We'll see. Was out to Gibson's [my local You Pick] and was window shopping looking at other Buicks. Found a pretty nice floor mat with the Buick Tri shield logo on it. It was a light beige so I washed it up real well, allowed it to dry and just sprayed it with the tan spray recipe found in the "How To" section. Think it's going to turn out pretty nice...
  18. I had considered buying a second one to revive, but people are asking way too much for them for the amount of work that needs to be done. If I could get one for $500, that might be doable, but $2000 is a bit much. Then I also see a lot of finished ones up for sale for a really long time, like 8 months or more. When you can't buy and you can't sell, unfortunately that doesn't bode well for doing a profitable project ☹️
  19. Anthony
    Floor jack hack
    Nice 👍 I learned the hard way where the jacking points are by accidentally jacking my floor pan 😁🤦‍♂️
  20. I generally follow whatever recommendations I see from GM, but this time it failed spectacularly. A service bulletin from the '90s said to upgrade the oil pan gasket to their new design from AC Delco which is supposed to be so good that you can even reuse it. The first thing I noticed was that it didn't fit very well. It was floppy, hung over the edge in places, and getting it to stay in place while installing it was like trying to make a fish sandwich while it's still alive. The instructions that come with it and in the bulletin say to torque the bolts to 10, then 16. This seemed to squeeze the gasket out, and deformed my new pan. It started leaking and progressively got worse, so I ordered a new gasket. This time I ordered the Fel-Pro PermaDry Plus. This gasket is a solid piece that doesn't flop around or squeeze out. It comes with 4 handy helpers called SnapUps that you screw into 4 bolt holes, and they hold the gasket and the pan in place in exactly the right spot, freeing up your hands to put the bolts in easily. Once you get a few bolts in, the SnapUps just unscrew and you can put the last 4 bolts in. Incidentally, I tried doing a search for "oil pan" on this site, so as to avoid make a duplicate thread, but the search doesn't seem to be working. It returned zero results, even though there is another thread on that very page about oil pan bolts.
  21. Anthony
    Oil pan bolts???
    There should be two longer bolts for this bridge
  22. Dave, If you're lucky maybe just replacing the seal behind the clutch will fix it.
  23. Got it out this spring and the A/C compressor looks like it gave out over the winter. there is compressor oil with leak detector all over the bottom of the car as well. I set an appointment with a shop the 2seater uses as they still have R12 equipment. I just have to provide the R12 and oil which I have plenty of.
  24. Earlier
  25. Went to my first cars and coffee today, meeting up with my friend Kendall and his wife. He has a 1971 Roadrunner and his wife drives a 1972 GTO, both great looking cars. Too cold to hand around so I left after an hour or so. About 100 cars.
  26. And actually 2 seater the switch he is looking to install were from my tested backstock inventory that you also tested with your "homemade test rig" so it's good. However from his post changing the accumulator is more likely what he needs to do. I have replaced the pressure switch twice in my 333000 miles on the Red. The switches can be hard to remove because they are in tight, which is why I bought the specialty socket [they are thinner wall because of the lack of clearance] years ago for this purpose.
  27. I have tested numerous accumulators and pressure switches on my homemade test rig and I have found the pressure switches to be very reliable and robust, unless, they are leaking fluid through the electrical connection. If the connection is wet, replace the switch. The set pressures for warning lights and pump operation have proven to be quite accurate across switches I have tested. If the red brake light is turning on without activating the pump, odds are it is fluid level or likely the parking brake release. The set pressures in the switch for the lights and pump activation are a couple hundred psi, or more, apart.
  1. Load more activity
  • advertisement_alt
  • advertisement_alt
  • advertisement_alt
  • Top 20 Contributors To The Forum
    1. Ronnie
      3888
    2. DAVES89
      2159
    3. 2seater
      1964
    4. Padgett
      1077
    5. ship
      600
    6. Philbo
      365
    7. fun car guy
      349
    8. Frogware
      237
    9. jon L
      237
    10. Ron Walker
      225
    11. retired mechanic74
      164
    12. BlakesReatta
      161
    13. alchemist
      151
    14. ski.dive
      149
    15. Ohjai
      142
    16. DPS.01
      140
    17. AZ Ron
      138
    18. Studebaker
      137
    19. Posti
      136
    20. Top Down
      129
