- Past hour
- Today
That's a good deal. As we know from past experience, the price of shipping can be really high on these heavy items.
It looks like my local You Pick is going to clear out the row that the Reattas are in soon. They have already started on that row. There are 3 Reattas that have the Teves pump and motor yet in place. I have all I need but will pull and sell to anyone interested. They will come with the pressure switch and accumulator ball but I will not guarantee that the they work. I will check to be sure the pump runs. Price will be $250.00 delivered.
- Yesterday
The Regal has been running great. Hate to say it, but I like the extra room the Regal has so I use it more and more. One of my cars has to stay outside [the Regal] so I only drive the Red when I know the weather is going to stay nice.
- Last week
Claus joined the community
Pastor Matt joined the community
Yeah, I agree that some chrome wheels are needed. Even though it has the "premium" wheels for that year, it has the same problem the stock Reatta wheels have. They look too much like hubcaps. They don't add much bling to the car. In my opinion wheels can completely change the look of a car. I'm just waiting for the right wheels to come along locally at a good price. -
ship replied to Ronnie's topic in Reatta Owners Journal Forum
Ronnie, I'm liking the car...maybe a set of chrome mags to add to the mix... -
2seater replied to Ronnie's topic in Reatta Owners Journal Forum
Shouldn't that be "MYSTANG"?😁 -
E044 Code after timing chain replacement
2seater replied to rpetry's topic in Reatta Owners Journal Forum
Since this is a recent purchase, it would be a good idea to replace the O2 sensor just as a maintenance item. The comment about the o-rings above would seem to indicate perhaps some service work was performed incorrectly as well. -
There should be no vacuum connection to the EGR system, which is all electrically operated. The line mentioned above does run somewhat near that area and it connects to both the HVAC and also supplies the cruise control vacuum system. It is possible the plastic line was displaced so it touched something hot enough to melt it.
ELVISTAR started following Vacuum line
I was looking under the hood of my 1990 reatta I saw a vacuum line curled up plastic Unattached That ran towards the firewall It is connected to the egr valve It was broken off to the left (Passenger side) inside the wiring harness I guess it controls the hvac Door Good Luck ELVIS
ELVISTAR joined the community
rogold replied to rpetry's topic in Reatta Owners Journal Forum
I think if the injector rail is bolted down correctly, the injectors should be pushed into the manifold far enough to where you dont see the O-rings. Maybe a pic if what you see will help. -
Ronnie replied to rpetry's topic in Reatta Owners Journal Forum
I don't see how changing the timing chain could cause that code. Since it is sporadic the culprit might be a problem with the EGR valve. The EGR has three ports and one of them could be sticking in the open position randomly causing a lean mixture. I would check the EGR first before doing all the other work you described. BTW, you can open and close the 3 EGR solenoids using the onboard diagnostics while the engine is running to see how they respond. If you cycle them repeatedly maybe you can catch one of them sticking open when it should be closed. -
I started getting this code after my timing chain replacement on my 1988 Reatta. Just to preface, when I bought this car 2 months ago, my cam position sensor magnet had fallen out of the sprocket and I was getting the E041 code all the time. No E044 at that time. So since my car has 84K miles on it, I decided to just replace the timing chain, damper and water pump as well. All is now working fine, no more malfunction codes except E044 sporadically. I know from research many things can cause E044 to show up. My vacuum hoses are all good, but one thing I did notice on the fuel injectors. I have not taken them off yet, however it seems that the bottom o-rings are just sitting on the intake manifold and appear to be old. Could a leak here cause this code sporadically? It seems if they are not sealed good here, it could cause the computer to up the fuel mixture to more more fuel and cause it to be a little on the lean side. I will take those off and inspect them this week and put new o-rings on them to see if that makes a difference. I am open to other suggestions as well.
Yeah, I took some pictures of my Reatta there. It's a popular place in the center of town for taking photos of cars. The mural is there to remind people that Kingston was once called the "peach capital". Over a million peach trees were planted in this area. It was a huge industry that died almost overnight when a blight hit the peach trees and killed them. My house sits on land that once a peach orchard. I always wonder who the old man in the mural is supposed to be and why he is looking so intently at the back of the young lady picking peaches. 🙂 -
DAVES89 replied to Ronnie's topic in Reatta Owners Journal Forum
Looking good Ronnie! Didn't we see that mural with your Reatta? -
I finally got a front license plate I like. It's a replica of a blue Tennessee license plate like is on the rear of the car. I think the blue goes well with the bright white paint. I still want some different wheels but not in a hurry to get them. -
Carpet removal / center console hump
Anthony replied to El-Grumpo's topic in Reatta Owners Journal Forum
How did you get that piece out? -
El-Grumpo replied to El-Grumpo's topic in Reatta Owners Journal Forum
Wow, thanks for the references! I guess I didn't do my homework enough, but I was able to figure it out with a bit of observational guesses. Next up is lots and lots of cleaning, but I can do that at my leisure. -
Thanks 2seater, guess I’ll remove air box and check both 👍
The hood might just be stuck. Hold the hood release lever out and get someone to push up and down on the front of the hood and see if it pops up. I had this very same thing happen on an old Mercedes I bought and it took me quite a while to figure out why the hood wouldn't open.
- 1 reply
- 3
I put my Reatta into my back garage for the winter. When i went to get it the hood latch did not open the hood. I am sumewhat disabled and need some info. Is there a way to open the hood without the latch puller? Does anyone sell latch lever set up? Thanks in advance
Well this isn’t the first time this specific headlight motor has had this problem of not working for a while then all of a sudden working again. im going to assume it’s gonna happen again. When it does? Any suggestions to diagnose it? Whats this about a brush inside the motor not making contact?
Be thankful and hope the problem doesn't return. 🙂
Before I had a chance to check it with a multimeter, it all of a sudden started working again. Any ideas?
It's not apparent from the manual how to take that rear piece out
3905 -
2169 -
1976 -
603 -
143 -
130
