Philbo Posted February 24, 2021 Share Posted February 24, 2021 8 hours ago, Ronnie said: Any tips you can give on improving the instructions for replacing the magnet to make them better? I would agree with the statement, but not sure there is anything to improve on the instructions. They were very clear to me. I think it just sounds more intimidating than it actually is. 1 Link to comment Share on other sites More sharing options...
Danpatters583 Posted February 25, 2021 Topic Author Share Posted February 25, 2021 On 2/23/2021 at 9:40 AM, Ronnie said: Any tips you can give on improving the instructions for replacing the magnet to make them better? It was mostly just me overthinking stuff. The procedure was written very well. Will add though it doesn't matter if you get a little jb weld on the front of the magnet. I got a little bit on mine and it still appears to have worked. The harbor freight magnet seems to be the best option to install it. Also maybe, mention that its easier if you remove the coolant resivoir and water pump pully to get to it. Otherwise its pretty straight forward. Link to comment Share on other sites More sharing options...
Ronnie Posted February 25, 2021 Share Posted February 25, 2021 4 hours ago, Danpatters583 said: Also maybe, mention that its easier if you remove the coolant resivoir and water pump pully to get to it. Otherwise its pretty straight forward. Thanks Dan. I might add that to the instructions. Link to comment Share on other sites More sharing options...
