jon L Posted September 6, 2020 Share Posted September 6, 2020 Using the computer, I cut down the idle to where I want. Now how do I lock that setting in so it won't change when I restart it.? Please anyone. Link to comment Share on other sites More sharing options...
2seater Posted September 6, 2020 Share Posted September 6, 2020 I don’t know of any way to lock in an idle speed achieved through the diagnostic overrides. Pretty sure it must be burned into the chip Link to comment Share on other sites More sharing options...
jon L Posted September 6, 2020 Topic Author Share Posted September 6, 2020 I would think there is a way to change it. I can change it with the incar computer ,but can't lock it in. If they let you change it, wouldn't there be a way to lock it in? Link to comment Share on other sites More sharing options...
2seater Posted September 6, 2020 Share Posted September 6, 2020 I think the overrides are for test purposes only and cannot be altered permanently without reprogramming the chip. Link to comment Share on other sites More sharing options...
jon L Posted September 16, 2020 Topic Author Share Posted September 16, 2020 (edited) UP-Date: Idle problem. (fast 2000rpm) Changed throttle position sensor, No change. Changed all other sensors. No change. After reading the fine print in the shop manual I discovered that the throttle sensor must be adjusted thru the computer. o be set to the correct voltage. Takes two people, one in the car to watch computer and one to adjust the sensor. I had to bend the tab on the sensor to get the correct voltage. Guess what, the correct idle speed. Edited September 17, 2020 by jon L 2 1 1 Link to comment Share on other sites More sharing options...
Ronnie Posted September 16, 2020 Share Posted September 16, 2020 Good to know. Thanks. Link to comment Share on other sites More sharing options...
