Dan Alesi Posted September 1, 2020 Share Posted September 1, 2020 While diagnosing my 91 Reatta, I was able to retrieve codes for everything except the ABS. The light remained on and did not flash. Any suggestions would be appreciated. Link to comment Share on other sites More sharing options...
DAVES89 Posted September 1, 2020 Share Posted September 1, 2020 The "Service Engine Soon" light flashes when reading the codes not the yellow amber brake light. I believe on the 1991 Reatta [I don't have one] you still have a gray "ALDL" box under the dash that you have to jumper the pins. Directions how are in the "How To" that Ronnie has on the top of the page. 2 Link to comment Share on other sites More sharing options...
Dan Alesi Posted December 4, 2020 Topic Author Share Posted December 4, 2020 Ronnie,The service soon light does not flash, any idea? I understand that a Hard Code will prevent this operation. What is a hard code? Thanks Again. Link to comment Share on other sites More sharing options...
Ronnie Posted December 4, 2020 Share Posted December 4, 2020 This topic is about ABS so I assume that is what you are asking about. Sorry, Can't help you with a '91. It has a totally different ABS than other models. I have never worked on one and don't have a FSM for a '91. Link to comment Share on other sites More sharing options...
DAVES89 Posted December 4, 2020 Share Posted December 4, 2020 Neither do I. Link to comment Share on other sites More sharing options...
ship Posted December 5, 2020 Share Posted December 5, 2020 (edited) I highly recommend that you purchase a '91 Reatta & Riviera Factory Service Manual. They are available on eBay...worth every penny. The most likely issue you have with the ABS warning light staying on is that one (or both) of the front wheel speed sensors is bad. Unfortunately, these front sensors are a one-year-only 1991 design. The end of the lead (the sensor part) is made of black bake o' light type plastic with a small round metal probe protruding from the center (vs. an aluminum canister in previous years). Daves89 or Jim Finn or Marck Barker of eastcoastreattaparts might have or be able to help find them for you. The hydraulic modulator (located in engine compartment drivers side), or its contained relays (2 of them), or the EBCM very rarely go bad (if ever). IMO I'd concentrate on the front wheel speed sensors. Edited December 5, 2020 by ship 1 1 Link to comment Share on other sites More sharing options...
Dan Alesi Posted December 14, 2020 Topic Author Share Posted December 14, 2020 Thanks , I will do the inspection as given. Link to comment Share on other sites More sharing options...
Reatta John Posted December 22, 2020 Share Posted December 22, 2020 trouble codes 1989 Buick reatta 2 Link to comment Share on other sites More sharing options...
