Dan Alesi Posted July 25, 2020 Share Posted July 25, 2020 My brake light remain on after turning off the car. I removed the negative cable from the battery and waited a few seconds then reattached said cable. The lights turned off and remained off. My concern is that it may happen again. Is a new switch needed, and if so, where can it be ordered? Link to comment Share on other sites More sharing options...
Ronnie Posted July 26, 2020 Share Posted July 26, 2020 Welcome to the ROJ forum!. You might need a new brake light switch but the switch could just be out of adjustment or the pedal might be sticking before it returns all the way back to the top. Next time it happens reach down an pull up on the pedal and see if the brake lights go off. I'm not sure why disconnecting the battery cable made the brake lights stay off. Link to comment Share on other sites More sharing options...
