Remenber the fix?
jon L
A while ago someone wrote about his engine revving high when he started it. About 1500 if I remember correctly.
What was the fix for that? any  one remember?
I would try cleaning the idle air control. Both the control and the housing.
Did that.no help. It still idles fast occasionally. Not every time it is started.
when it starts and idles fast I shut it off and restart it and it idles normal.
I don't know the answer to that one either. I may have mentioned in the past that my 89, which unfortunately gets little attention, does something similar. When this happens, I can go to overrides and force the IAC toward closed to slow it down and it stays there, but I have never figured out what tells it to open up in the first place. High idle is usually associated with cold engine operation, but the engine coolant and incoming air temp. seem normal. Now that I think of it, I wonder what would happen if either or both of them were disconnected? Might it always default one way or the other. I don't know and that's little help, but it might give a clue.
