turnstone1 Posted June 3, 2020 Share Posted June 3, 2020 Hello Reatta owners... I misplaced the key for my friend's long term stored Reatta.....! Need to move the car out of the way...blocking a driveway... Any, relatively easy way, to get car out of neutral? And even better, to unlock the steering wheel... After looking for DAYS for the misplaced key....I am not likely to find...those keys. Getting a locksmith....at his rural property EXPENSIVE... After some exhaustive searches on the web....didn't get far.. Any suggestions? Thanks in advance. Paul Link to comment Share on other sites More sharing options...
rogold Posted June 3, 2020 Share Posted June 3, 2020 If the car is on a large level concrete pad, you could buy or borrow some car dollies and push it aside until you find the keys. https://www.harborfreight.com/1000-lb-capacity-vehicle-dollies-2-pc-61283.html Link to comment Share on other sites More sharing options...
turnstone1 Posted June 3, 2020 Topic Author Share Posted June 3, 2020 Hello, Thanks for the suggestion.... However, car is on a sloping, loose gravel driveway..... Attempting at dragging out of the way, with a tow strap...... Not so successful... with harbor Junk strap....I mean harbor freight tool strap.... HF hit and miss quality... Don't get me wrong, half my tools are HF.....! Murphy visited me... First I loose the key....then the attempt at dragging...not too successful...and now I have to put up with my friend reminding me to never buy HF tools.... Thanks... Paul Link to comment Share on other sites More sharing options...
Ronnie Posted June 4, 2020 Share Posted June 4, 2020 Open the hood and remove the shifter cable (3) from the shift lever (5) on the transmission. It just snaps onto a ball on the shift lever. Then move the shift lever to take the transmission out of park. You might need some helpers to push forward on the car to make it easier to move the shift lever if the car is on a hill. If you want to turn the wheels you will either need to find the key or tear up the steering column. Link to comment Share on other sites More sharing options...
turnstone1 Posted June 4, 2020 Topic Author Share Posted June 4, 2020 Thank you.... Thanks for the response...and excellent suggestion.... Best Regards Paul 1 Link to comment Share on other sites More sharing options...
