Finding Reattas in Salvage Yards
Posti
I located an 88 coupe in a local junk yard by going to www.car-part.com and searching for Reatta parts.  This is a commercial site used by body shops, but it works fine for individuals as well.  You can sort by region, and it will also list by distance from a zip code.  The list is not always up to date - one local yard had crushed their Reatta long ago, but the other still had one that was surprisingly complete.  All the glass is there, as was the IPC and CRT - the IPC was no good, sadly, but i was able to pick up some missing fasteners and clips which they waved past, and a complete if mostly fried window switch I can try rebuilding for $5.  The taillight assembly is intact and available for $65, so I plan to go back.
Anyway, check out car-part.com and see if you have any Reattas lurking close to home!
