1989 Reatta shutters and pulsates when accelerating
Todd witcher
I Just purchased a 1989 Buick Reatta The car sounds fine at a idle but is soon as you gas it it’s the shutters pulsates in just won’t go. I’ve checked all the plugs are getting spark fuel pressure is good The computer says wiring problem with the engine
  • Ronnie changed the title to 1989 Reatta shutters and pulsates when accelerating
Welcome to the forum Todd!!  You should check to see if there are any trouble codes stored in the ECM and post the codes you find.  That is the first in diagnosing your problem. Instructions for checking codes can be found here.
