Judsramair Posted October 1, 2019 Share Posted October 1, 2019 Ignition key have had trouble with my key I have to tilt wheel in a certain position to start and stop the car now I have nothing any ideas I am fixing to try to tear into the Staring column and see what I’ve got going on Link to comment Share on other sites More sharing options...
Ronnie Posted October 1, 2019 Share Posted October 1, 2019 The symptoms you describe sounds like the ignition lock rack might have broken. When you turn the key a gear on the lock moves the rack up and down to activate the ignition switch located at the bottom of the steering column. If that is the problem it can be a hard job to fix it. Replacing the steering column might be easier. Link to comment Share on other sites More sharing options...
