Guest Nico2751 Posted December 24, 2017 Share Posted December 24, 2017 Both headlights are stuck in the up position and won’t go down Link to comment Share on other sites More sharing options...
DAVES89 Posted December 24, 2017 Share Posted December 24, 2017 There is a headlight button in front of the shifter. It allows you to raise and lower the headlight pods without turning on the lights.That could be your issue. Link to comment Share on other sites More sharing options...
Ronnie Posted December 24, 2017 Share Posted December 24, 2017 If this car is new to your then you should check to see if someone has ran the headlight doors up to the open position manually and then unplugged the motors. It is a common occurrence when someone is selling a Reatta. Link to comment Share on other sites More sharing options...
