ski.dive Posted November 27, 2017 Share Posted November 27, 2017 Where is the low side located to add R-12 to the 1988 Reatta? Link to comment Share on other sites More sharing options...
DAVES89 Posted November 27, 2017 Share Posted November 27, 2017 It is the silver cylinder looking item located near the rediator. How do you know you need it and do you know how much to put in? Having too much freon in the system is as bad or worse then not enough. You might be better served making sure the adjustments are correct for the door opening. You will have to remove the glove box to see the door arm operate. 1 Link to comment Share on other sites More sharing options...
ski.dive Posted November 27, 2017 Topic Author Share Posted November 27, 2017 I do not need any freon for now, just could not find the low side for adding R-12 when I need it. Link to comment Share on other sites More sharing options...
